I’ve been using the SITL for Copter 3.5.2 for some time now and am testing the latest version, 4.0.3. I have a custom c++ interface that I use to connect to the SITL which has worked well with both versions of the SITL, however when I connect Mission Planner to the 4.0.3 version of the SITL, the SITL crashes. When I have my software connected to port 5760, it crashes as soon as I connect mission planner to 5763. It also without my software connected / running when Mission Planner connects to port 5760.
The SITL does not crash when I only connect my interface to it. In the 3.5.2 version of SITL I can connect both my interface and mission planner without issue.
This is the error that is printed when it crashes:
stack overflow in thread FTP
Running sh dumpstack 8528 >segv_arducopter.8528.out 2>&1
Failed
The segv_arducopter.8528.out
file then just contains:
sh: 0: Can’t open dumpstack
I hope and assume this is unique to the SITL build–I assume that if a bug this serious had occurred in hardware it would’ve been found very early on in beta testing. The binary for the SITL I was running was obtained from: https://firmware.ardupilot.org/Copter/stable/SITL_x86_64_linux_gnu
Also, when fetching that, I noticed that there was also a SITL_arm_linux_gnueabihf version which I think is awesome since as far as I knew the SITL wasn’t supported on ARM. What would it take to port it to 64 bit arm (aarch64)?
