Hello, I’m running an old WEMA Sinus-8 ESC on my Plane which has an MATEK F405-WTE onboard.
The problem is that if i power the Plane, the FC takes too long to start up.
The ESC has a failure report if, after getting Voltage on its Power connections, there is no PWM Signal for 10 seconds. After a Failure report it doesn’t react on PWM input, an i can’t turn that function off.
Is there anything that I can do that my FC sends out PWM Signal 1000 within 10 seconds after connectiong to the Battery
