My current project has a Holybro Pixhawk 6C Mini flight controller, and a Mateksys M9N GNSS receiver.
I’m connecting the M9N receiver to the GPS-2 port (Serial 4) because it has the smaller connector without the leads for the safety switch or LED’s.
I’m finding that to make it work, I have to set both GPS_TYPE and GPS_TYPE2 to “1” for auto. If I set either of them to “0” for disable, the GPS doesn’t appear to report data.
And if I set the GPS_TYPE to the value for “UBLOX” then ArduPilot doesn’t seem to see the GPS either.
Interestingly - with both GPS_TYPE and GPS_TYPE2 set to “1” for auto, the HUD shows “NO GPS” but then shows the fix level. (3D DGPS in this example) Maybe this is a Mission Planner issue.
Also - displaying the HUD’s user items for SATCOUNT and SATCOUNT2, and GPSHDOP and GPSHDOP2 - it appears that the GPS receiver is identified as “number 2.”
I saw in the comments of some of these parameters that the next firmware release will rename some of these parameters.
In the mean time - I’d like to make sure I’ve got this thing configured properly.
Thank you!
