Simulation with actual parameter file
I have succeeded with SITL simulation using the default parameter file plane.parm. This file has only 81 parameters. However, I would like to use as much as possible from my actual Skywalker plane parameter file, for simulation.
Is there anywhere I can find out which data from the real parameter file I can use without breaking the simulation?
Thanks, Helge.
