Hi All,
I have set up the SITL environment according to basic setup on the web. Everything was fine and working, but the plane is a bit fast in simulation. I have tried to look at “time” command in MAVProxy and I have found that autopilot clocks diverge from the GCS clocks and run 10x faster. The same observation was done in ArduPlane window:
Rate: target:1200.0 achieved:13063.5 speedup 10.9/1.0
I have tried --speedup=1 option, but without any effect.
Hi, I am experiencing the same (copter), I have an install running in wsl (speedup 16.2/1.0, so hanging on tight). In Ubuntu 18 all works. It’s observed in mavlink SYSTEM_TIME.time_unix_usec.
Did you investigate this further?
Hi Peter,
Thanks for the reply. There seems to be a problem with the system time in wsl, which is faster (10-20 times). I do not see this when running on linux. SIM_SPEEDUP will not alter this even if I reduce it to 0.1 to match. I will look at it some more as I am not that familiar with running this in windows.
I reinstalled to ubuntu 18 on wsl1 (from ubuntu 20 on wsl1), and it works fine now.
Rate: target:1200.0 achieved:1198.7 speedup 1.0/1.0
Not sure what happened here, if its the os version or something in my previous install. Thanks again.
Hi all and thank you for reply. That is what I have forgotten to remind, that my system is also WSL2 with Ubuntu 20. It looks like the same problem. I will try to put it on Ubuntu 18 and reply if it also works for me.
I want to third this post. Unintentionally set up SITL Simulator within WSL2 with Ubuntu 20.04. Ran into the same accelerated simulation issue. Sim SpeedUp Scaling attempts have no impact.
