Alexmos serial does work really well. Ignore my advice but I’ll leave it up for anyone searching who has the problem who is using Mavlink.
I’ll make a set up next week and try to replicate your error.
Make sure stabilize pan is checked in your gimbal screen in mission planner.
If that doesn’t work, while connected to mission planner set mount to rc targeting- if it starts to follow yaw, change your MNT_DEFLT_MODE to 3- RC targeting.
I never got mine to work, my psychiatrist told me I should stop trying. I’d love to see your settings of you manage to get it going again. Best of luck.
Haha now I’m totally confused, those yellow, blue and white cables are plugged into fc_roll, fc_pitch and AUX1 respectively.
So that’s AUX for one way mavlink connection? Surely not using FC_roll/pitch ??? never heard that mentioned.
put mavlink tx on RC YAW (on mine picture blue wire directly soldern on board )
put mavlink rx on RC ROLL (on mine picture yellow wire directly soldern on board)
set telemetry port to 115 , protocol mavlink 1 , choose storm32 on gimbal page of MP optional hardware , set mnt_rc_in_roll to some chanel , do the same for tilt and pan …
Sigh,checked double checked. brd_ser2_rtscts:0. Nothing, I reset every time. I’m guessing the the simple bgs will just pickup the mavlink connection in the green lines on the mavlink tab, at one point i got 512 packets received but don’t know how or when. It could be working but the gui doesn’t show it??
I’ve sent an email to Jakub at hdair studio and see what he says.
Tried three different firmwares. Tired.
Thanks again for your help Danijel!
On the other hand I added a bluetooth adapter via the serial port which was a doddle comparatively. Using the Basecam android app is great. The control mode is pretty, gimbal follows you phone direction, actually very impressive.
I am looking around how to connect tiny board to mavlink , since it has no rc roll input witch I have used for mavlink tx , can I asumme I could just plug mavlink tx an rx to tiny board TX and RX pins that are specified as uart to bluetooth…
I was thinking of using the serial port for fc mavlink. But for some reason in the literature is not mentioned as another channel for mavlink, or as a uart port. It’s buad rate is 11500 by default so good there. The simple BGC manual is pretty good. It says the tiny has rc_roll and Rx on the same pin. Surely it has rc_roll? Simple bgc_32bit_manual page 38
