Hello, I have a quadcopter pixhawk and simonk ESC 30A, motor 9020k readytosky, I try to calibrate Esc but not calibrated, I test the motor A =13% throttle
B=14%
C=14%
D=8%
WHAT CAN I DO??
Can you explain how you did the ESC calibration ?
Calibrate by pc through mission planner calibrate ESc
Or by remote Control
Throttle high level and then connect battery and I returned the throttle to 0
Did you press the safety switch ?
Did you get any ESC beeps ?
why you dont try to calibrate one by one wtih the receiver th. output ? and then try again all
