Hello, I’ve been trying to run SITL on windows through cygwin (as what is told in the documentation). I’ve gone through the set up in order, from downloading cygwin, clone the git, download mavproxy (though the latest mavproxy has some issues that I installed the previous version, which cant be run if the master args isn’t meddled with (auto connect and failed to 0.0.0.0:14550)), and run ../Tools/autotest/sim_vehicle.py --map --console
as you can see, i’ve tried adding parameter to the mavproxy to run at master=127.0.0.1:14550 in which port mavproxy is able to run. any guess what might be wrong?
im trying to run SITL on flight gear, but this issue hindered me. thank you!
thank’s for the reply. the thing is, im trying to run the first step of doing SITL from windows (which is this step SITL setup on Windows using Cygwin (not recommended) — Dev documentation). That step alone i can’t manage. And i’ve tried your line, it still prints the same and do nothing.
im trying to rerun the setup how-to from the docs step by step now
edit:
Rerun the SITL setup from the beginning is the best choice. now SITL is working! Though, I curious about this messages which: no osascript RiTW: Window access not found, logging to /tmp/ArduPlane.log
i tried installing osascript through pip in cygwin, but one of the dependency raise this error platform cygwin is not supported so i didn’t continue the osascript installation.
if anyone can answer, it would be appreciated. but if not, then it’ll be for next time then.
