I tried to connect my telemetry module (HM TRP) with mission planner but it is not able to connect. It is throwing an error “Fail to enter command mode” and in the hardware it is showing solid red light.
Can someone help in resolving this issue.
I ask which exact module und pins you are using.
So I assume you use a original Hope Microelectronic HM-TRP 915s module and you also have the documentation of this modules downloaded.
How are ALL pins of this module connected, (Vcc; Gnd; Tx; Rx; Config; Enable; Test) ad also which pins of the Cube are used. Not only the connector type but all the single pins
