SiK 2.0 Hex File
I need to make a 915MHz Holybro compatible with a network with all other radios running SiK 2.0. For some reason I can’t seen to find a repository with older versions. Could anyone please direct me or attach a version that you may have saved - Many Thanks
Hi @Brad_Snelling
radio_hm_trp_V20.zip (36.3 KB)
Hope this helps.
Many thanks! I eventually found that QGroundControl loads and references a 2.0 from AWS. Its odd that MP updates to 2.2 and GGC updates to 2.0. I am probably missing something.
Hi @Brad_Snelling ,
Some time ago there was a similar question about the Sik radio firmware versions.
Without a deeper dive in the source code (here) more can be found here (Sik 2-0 vs 2-2).
