Hi everyone! Weird event yesterday: During an ARM sequence, three motors didn’t spin.
Context:
- This drone has done two flights a few hours before, completely normal;
- There was no beeping and the armset LEDs were on, so both signal and power were there;
- Without any reboot, we tried to ARM again and the same three motors didn’t spin;
- After a hard reboot, not even touching the rest of the drone , they worked normally.
- After the successful ARM test, we did a short flight. All nominal
SETUP
- Cube Orange+
- Kore carrier board
- Armset T-Motor MN705 + ESC Alpha 80A HV
Considerations:
- We had similar thing after getting some water inside the armset. However, three motors at the same time is lottery-unlikely to happen.
- After the event, the battery was put in the charger and it was saying “Cells Voltage High”
- We know that the ESC can protect itself from some electrical abnormalities;
- I really don’t think it is a damaged cable because, again, three motors at the same time.
- Checking the log, PWM was also there.
Questions:
- Have you seen something like that?
- Could a battery issue cause such a behavior?
LOG
