are you getting the motor to move using the vesc software ?
Can I continue this conversation with you in a couple hours need to go out for a bit
are you plugging it into the cube upside down? the white signal wire should be at the bottom.
White on the bottom the steering servo is working
No I am not but will try again tomorrow
When I try to configure the APP SETUP WIZARD there is no choice for PWM just PPM. What should I do ?
its the same thing on the vesc app. just select ppm.
I want thank Geofrancis & Randy for assisting us to get our flipsky ESC working. Without your help
I am not sure where we would be with this project. It was much appreciated
Prior to damaging our boat with powering up with wrong polarity we were trying to tune the boat to go straight during a WP MISSION rather then traveling
like a snake from one way point to another. I know there has been some discussions about this problem
Randy or Geofrancis do you happen to have links to these?
Hi @fisheye62
Glad that things are progressing.
The most likely cause of βwobbly pathβ is the turn rate controllers need tuning.
