Probably yes, But is it possible to setup a rover without the need of a transmitter.
The reason I ask is we want to build a test rover platform to do measurements on a farmland autonomous.
So there is no need for a manual mode.
It basicly has to run a mission autonomous setup in mission planner and perform a certain action at given points.
I have a Kakute F4 V2 lying around and thought it was a good idea to use that for the test rover. But it’s a bit of pain to setup and I fear I will run into problems later.
What other boards/options are great for an autonomous rover on a budget?
It is possible to setup a vehicle without a transmitter but for safety’s sake it’s best to have a transmitter. It’s also very useful when it comes time to tune the vehicle.
Yes true I did not plan on not using a transmitter, it’s just that I had to use my reciever in a tricopter.
I planned on using a uhf system and have a transmitter for it lying around, but the kakute f4 v2 does not seem to support ppm.
If I can at least test the motor output without having a transmitter connected then I can at least continue this project
