To set the Home you can do with the parameter:
-Home coordinates
or with the parameter
-L NameOfSavedCoordinates
saved in locations.txt.
Example: Ballarat=-37.598705,143.881744,485,165
The question may seem silly but what is the coordinate system? Why using 4 numbers? The first two longitude and latitude, which are the other two? What is the name of this coordinate system so i can move from one system to another?
Hi, I am trying to add to the locations.txt file. I have two valid format locations added to the file but when starting and calling either of these locations I get an unknown location error. Do I have to rebuild it all for these locations to be picked up? Thanks for any reply.
No rebuild is required. Try using a file in your home directory instead
of modifying locations.txt:
