Both modules need to be operating nominally with good fixes for GPS yaw to be calculated. If one GPS fails in a moving baseline configuration, the yaw source will fail, and GSF will become primary.
In my experience on a Rover, a few seconds of GSF fallback results in no perceptible performance loss. However, things can start to degrade quickly, and I would not drive my (large) Rover in any autonomous mode using GSF as the primary source for more than 15-30 seconds. Your mileage may vary, as the Rover where I have the most experience using moving baseline is very noisy with a combustion engine and mower blades, which likely impact GSF precision significantly.
