Set-position-target for Yaw, Yawrate in 3.5.3
Hello quick question,
just moved to 3.5.3 and saw that “1) Guided mode support yaw and yaw-rate fields from set-position-target message”
I have been using set position target for x,y,z and I am using set roi for the yaw. This worked for 3.5.2 but in 3.5.3 the vehicle yaw points towards the north.
According to this:
http://ardupilot.org/dev/docs/copter-commands-in-guided-mode.html#copter-commands-in-guided-mode-set-position-target-global-int
I am using the following bitmask 0b0000111111111000
Any recommendations?
Hi @kostkar,
So, what you are trying to do is set the (x, y, z) and (yaw, yaw_rate) of your drone using the SET_POSITION_TARGET_ command? :slight_smile:
I would think that the bitmask should be:
0b000111111000
Hopefully he found a solution in the last 3 years :slight_smile:
