Hi;
Where can I set the initial movement speed and cruise speed on the ardurover. When I turn on the electricity the motors run very fast.
Hi;
If the motors start to run immediatly after connecting the battery, there is something wrong with your setup.
Please read:
completly and carefully
I’ll use an analogy for my guess. If you start your car with the accelerator pedal pushed to the floor what would happen?
I guess I was misunderstood. The car does not start when the battery is connected. How can I adjust the speed while controlling it with the remote? I want it to go slow even when I give high throttle from the remote.
Hi @ramada,
In Manual mode the pilot has full control of the throttle so the best you could do is one of these:
These will reduce the maximum speed for all control modes. It might be better to instead drive the vehicle manually in Acro mode which uses a speed controller. This may require a GPS and/or wheel encoders but then you can control what the max speed is at full input throttle by setting the SPEED_MAX parameter.
It was the way I wanted. thanks
