So one day I’m flying my plane, miles out, and went to change flight modes and, instead, moved my ARMing switch and disarmed in flight. No biggy, I just lowered the throttle, moved it back to ARM and throttle was working again. One problem though. My distance and direction home was now at the place where I just rearmed…not my actual starting point. I was familiar with the area I was flying so was able to return home, but if I had failsafed my plane would go to the wrong home position. I do have a Rally Point set up within LOS of my starting location, but if the plane is closer to ‘home’ it will go there, not to where I am.
Is there an ability to have Arduplane set the home position at the first arm location vs where ever it was last armed? I think this would be a nice selectable function (Set Home at first arm location: enable/disable.
Thoughts?
FWIW, I set up a logic mix in my Tx so the disarm switch will not engage if my throttle enable switch is enabled AND throttle position is above -99%. Now I would get a repeating warning ‘Arm switch moved to disarm position’ if I accidently move the switch to the disarm position while in flight.
It doesn’t work so well on multicopters. Ask me how I know ![:wink: :wink:](https://discuss.ardupilot.org/images/emoji/twitter/wink.png?v=12)
to where I am.
Ah. Yes, that’s bad. If you specify the home position using a GCS you
won’t get the drifting-home-position.
Note that you can exclude the home position from your RTL calculations
with RALLY_INCL_HOME
Thanks. Yeah, I usually set a Rally point in front of my starting position when flying for a dedicated spot. I was having issues with RTL not using the Rally point and going into loiter directly overhead of the home position.
I rarely use a GCS and never tried setting the home position by a GCS prior to flying. I might have to try that out one day.
Well it seems Ardupilot already has the capability to save the home position on first arm. It’s Home_Reset_Alt. Default is 0, meaning will reset home each and every arm. -1 turns the feature off so it won’t reset the home position after the first arm. It can also be set so it resets home when the altitude is from 1-127 (meters?). I’m not sure I understand how that would work, but setting this to -1 worked and didn’t reset home when I disarmed and rearmed in flight.
Is there any way to achieve same behaviour in arducopter I dont want copter to change it’s home position everytime it arms
