Had a plane with an mRo Pixhawk working prior on an earlier Arduplane release. I upgraded to Arduplane 3.8.5 now and set things up the same as before.
But I cannot get the servos to move.
In Mission Planner I see the RC channels in changing as per stick movements on the transmitter. I also see RC channels out changing.
I measured 5.1 volts on the servo rail (separate regulator), and the servos do their usual twitch on power-up. They just do not move after boot-up.
I disabled the safety button feature. I calibrated the compass, the power module is delivering battery voltage, the GPS fix is good, it has a good RC signal.
I had the same issue with a Taranis plus and a X8R receiver in a Radian XL powered glider. Taking your clue I changed the brd safety to 0. That did not work. So I change the OVERRIDE_SAFETY to 0 as well and the servos worked before arming, the throttle did not. After arming the throttle and servos worked! Thanks much for the hint!
I’m glad you got your system sorted. I haven’t done an ardupilot project in a few years now and when I do again I’ll bet I have the same problem before remembering the valuable little tricks.
