Hello everyone,
It is armed and electric motor is working but servos are not working with Pixhawk cube.
Do you have any idea?
Regards
Hello everyone,
Regards
Is the 5V line of the servo rail externally powered? Pixhawk does not provide power to servos.
Also which flight controller exactly are you using?
Thank you for your answer
It is powered by the Pixhawk power module. In my previous attempts, 4 servos and electric motors worked together. Currently, only the electric motor can operate on all pins. I tried different servos and they don’t work either
Flight controller ist pixhawk cube orange
Best is if you can show more details of your setup.
1.How you connected in detail the servos pin by pin?
2.How you connected the Pixhawk power module to the servo rail pin by pin?
3.Did you mesured the voltage on the servo rail?
4.What are all your settings, parameters PARAM-file?
Thanks
Pins have not problem.
Main outs are 4,8 V
Other components , Electric motor, telemetry, GPS …, are working
I don’t think , there is supply problem
Parameters are same with videos and before setting
How are we supposed to help you if you give us only cryptic information?
Start by answering Juergens questions.
Then post a parameter file. (technically Juergens question 4)
Then post one or more pictures where we can clearly see
As long as you don’t tell us exactly what you did and how everything is set up, we will assume that you did something wrong. And no, “I did everything right” is not enough.
What pins? the pins of the servos? the pins of the servo rail? are they connected? if yes, what are they connected to?
What problem? physical problem? electrical problem?
Is that the voltage on the servo rail? If no, what voltage is it and what do you mean with “Main outs”? If yes, why don’t you call it “servo rail”?
Yes, and probably also yes.
What videos? Before setting what?
