Hi guys, i’m building a “quad plane” with have only 4 tilt rotors. I need to set “SERVOn_FUNCTION” to 46 - 47 - 75 - 76 for the rear and front servos. But mission planer > Full parameters list does not show these 46 - 47.
@iampete I thought like you. I made the connections as they should be. But the servos I set as 46 and 47 did not output from pixhawk. Especially when I gave the command to tilt, the front servos worked but the rear ones did not (i am sure about the servos are solid). i have the pixhawkcube black.
