Hello all,
I have tried numerous ways to make servo 13 and 14 work but forsome reason i failed to get any action from these two slots.
I can make servo9-12 work properly but not 13 and 14.
I cannot find anyother topic on this so if anyone has get these ports work i like to know how that happened.
I am using 3.5.5 on the copter and i have flashed it couple of times.
Need some help
Has anyone ever make this SERVO 13 and 14 worked ? If so how.
biggerb
(Thorsten Böckler)
March 11, 2019, 6:31pm
3
I have the same Problem with SERVO13/14. Cube with Arducopter 3.6.7
I measured the servo outputs with an oscilloscope and there was no PWM signal. Zero Volt Level.
Can’t find any Solution…
iampete
(Peter Hall)
March 11, 2019, 6:37pm
4
you need to set BRD_PWM_COUNT , in this case to 6
dkemxr
(Dave)
March 11, 2019, 6:39pm
5
BRD_PWM_COUNT to 6, RELAY_PIN and RELAY_PIN2 to -1 ? Works on the old Pixhawk.
