Hello guys!
I am trying to do a fixed wing plane. While I check my servo motors before the takeoff, I realise that servo motors move on their own. I think this is due to the frequencies mixing with each other.
Has anyone encountered such a problem?
Thanks in advice!!
What flight node are you in? They will move in every mode other than manual.
Hi Geo,
I’m in FBWA mode. when my plane was in ground and nonmoving so that servo motors must not move their own. but my servo motors moving all time when I give power. You can see my problem in that link.
Thanks!
its asking me to log in,
do they move in manual or is it just stabilised modes?
no its not manuel. It is FBWA mode.
but does it stop in manual mode its to determine if its a signal or controller issue.
Yes, you are right. It doesn’t move on manual mode. But we have a new problem. We reduce the 14 volts coming from the battery to 5 volts through the regulator and with this we operate both the pixhawk and the servo and radio frequency to which it is connected. When we connect only radio frequency to the pixhawk, it works smoothly, but when it is with servos, the value we read on the avometer drops to 1 volt. Could this be because pixhawk does not provide sufficient power dissipation?
