Having some weird issues with my blheli setup. Everything was working fine yesterday but had to restore settings to default after having some sik radio communications issues.
However today I noticed 2 things happening. After changin motor directions using SERVO_BLH_3DMASK I can no longer test the motors individually. If I choose for example to only test motor B all the motors will spin up at 100 percent regardless of what power percentage is selected in the power window. Its currently on 5 %
This also happens when arming the FC with my remote.
It does not matter what channel I choose the motors also refuses to change direction.
Ok I am going to enable that. Maybe its something that I missed. Quick questsion. If I change motor direction in Mission Planner do I only need to do a soft reboot or a hard reboot?
