I need help regarding the camera gimbal in optional hardware. I am using Tarot T3D- V gimbal and i have connected the Roll, pitch, yaw cables to Pixhawk’s auxiliary output pins 1 and 2. After powering up and connecting pixhawk to PC, In optional hardware, Camera gimbal no option is displaying.
as far as I know, it should show Servo or any name based on the gimbal but it’s showing nothing. Can anyone please tell me how should I solve this issue?
I am using pixhawk only. I was also using RFD 900x and TXMOD but it still showing the same. now it is just pixhawk and tarot gimbal. Is there anything I am missing?
If it’s a 1mb flash Pixhawk gimbal features are not active by default with V4.1.1 If that’s the case you can use the Custom Firmware Builder to enable features.
I’m working on the CubeOrange. So I checked that site out and I built a firmware set that has the desired gimbal inclusion, then when I try to flash the .hex file it generates I get a whole swathe of errors. Is there a certain way I have to download/instlal the firmware?
The gimbal features should be in the default firmware for the Cube Orange. This thread is about 1mb boards. So perhaps start a new thread and note what “I’m having the same problem” is.
