Serious vibrations on new build, can't solve
Hi!
I recently built this copter, and cannot seem to figure out this low throttle vibration. I have already: cut the PIDs way down, soft mounted the FC, and tried the recommended S500 profile.
Here is a video: https://www.youtube.com/watch?v=5xFUfep54BM&ab_channel=DuncanFPV
It is fully controllable in the air (acro and stabilize), but it wants to shake itself apart and over heat the motors, any thoughts?
Build:
Holy Bro S500 Frame
Emax 2807 1300k/v
7in props
Matek H743 Mini
Blheli_S 4in1 ESC
6s Battery
Vibe Quad Params.param (20.0 KB)
Well motors sounds like a pid issue to me.
Just in case send onboard logs for review.
Some of those parameters don’t look right for a 7" prop quad on 6S power. The recommended S500 profile is for much lower kV motors and 10" props. I would use the values suggested in the Initial Parameter Setup screen for 7" on 6S as a starting point.
Then post a link to the Flight log.
