ecarlesi
(Emiliano Carlesi)
July 17, 2024, 4:37pm
1
Hi all, this is my first post here, I’m new of this world
I have a problem when I try to configure the serials on a Matek F405 V2. Click on “Serial ports” and the page appear but is unusable, because the UI controls are misplaced.
Here a screenshot: https://carlesi.vg/wp-content/uploads/2024/07/screenshot-2024-07-17-182311.png
With others FC (Matek F405 VTOL and SpeedyBee F405) everything works.
I also try to disconnect the GPS but the problem persist.
My workstation is Windows 11.
Has anyone already had this problem? I searched but couldn’t find anything about it.
Thanks
Best Regards
Emiliano
Slansford
(Spencer Lansford)
July 25, 2024, 2:55am
2
Mine is the same way. Same flight controller as well.
florins1
(Florin)
August 4, 2024, 3:05pm
3
same here. Probably a screen resolution issue.
ecarlesi
(Emiliano Carlesi)
August 4, 2024, 3:42pm
4
Matek support told me to change the serial configuration from the “Full parameter list” section.
ecarlesi
(Emiliano Carlesi)
August 4, 2024, 3:46pm
5
It is not a screen resolution problem. The problem occurs only with Matek F405 V2, the other FC do not have this problem. With Matek F405 V2 I have this problem on two different computers. However, by acting from the “Full parameter list” section you can configure everything.
I have the same problem with SpeedyBeeF405. Although I can change parameters in Full parameter list, I still want to know what cause this.
Eosbandi
(Andras Schaffer)
November 30, 2024, 4:01pm
7
Are you using the latest firmware ?
The same issue with aocoda H743Dual. But It display normal with my pixhawk v6c.
ijustwant
(ijustwant)
February 17, 2025, 6:37pm
9
I didn’t have the problem with FW 4.0.6(?)
Now that i upgraded to 4.5.7, i got the same problem.
I use this FC:
The Holybro Kakute H7 Flight Controller is full of features including integrated Bluetooth, dual plug-and-play 4in1 ESC ports, HD camera plug, barometer, OSD, 6x UARTs, full Blackbox MicroSD card slot, 5V and 9V BEC, easy soldering layout and much...
Did anyone find a solution?
