Hi all,
Recently I starting to look at the ardupilot code from github. I’m struggling with a few issues.
The latest code from master was failing to compile. Fortunately I could work around it.
After making a succesfull build I couldn’t get the serial monitor working. I enabled CLI by the following code:
#if (CONFIG_HAL_BOARD == HAL_BOARD_APM2 || CONFIG_HAL_BOARD == HAL_BOARD_APM1)
//# define CLI_ENABLED DISABLED // disable the CLI (command-line-interface) to save 21K of flash space
#endif
and I disabled some features
//#define LOGGING_ENABLED DISABLED // disable dataflash logging to save 11K of flash space
#define GPS_PROTOCOL GPS_PROTOCOL_UBLOX // hard code GPS to Ublox to save 8k of flash
#define GPS_PROTOCOL GPS_PROTOCOL_MTK19 // hard cdoe GPS to Mediatek to save 10k of flash
#define MOUNT DISABLED // disable the camera gimbal to save 8K of flash space
//#define AUTOTUNE_ENABLED DISABLED // disable the auto tune functionality to save 7k of flash
#define OPTFLOW DISABLED // disable optical flow sensor to save 5K of flash space
#define AC_FENCE DISABLED // disable fence to save 2k of flash
#define CAMERA DISABLED // disable camera trigger to save 1k of flash
//#define CONFIG_SONAR DISABLED // disable sonar to save 1k of flash
I couldn’t get the serial monitor working. I thought after that that maybe the branch of the code might be the problem so I checkout tag: https://github.com/diydrones/ardupilot/tree/ArduCopter-3.1.0-rc8.
No difference
To make sure that it wasn’t a bug within the osx version of the Arduino IDE, I restored the original firmware within APM planner. After restoring the original the firmware, the serial monitor within the Arduino IDE was working again.
BTW I also tried to get terminal with APM planner working with the code from the master branch and tag 3.1.0-RC8 but then didn’t work either.
What am I doing wrong? How can I get the serial monitor working with the ardupilot code?
Already thanks in advance.
My configuration:
- 3DR Quad APM 2.6 (with Electronics kit)
- Arduino IDE Mac 1.0.3
- OSX Mavericks (10.9.2)
