Serial 5 as Mavlink 2 telemetry
Is there someone who successfully connected and configured a Sik Radio, for example, 433MHz, to this CONS SBUS port and got a healthy GCS link? It seems supported. Is there any additional configuration parameters?
I connected pins 2, 4, 6, and 3 (5V, power via Servo rail) of CubeOrange carrier board, not working.
Is it true it is disabled for the users?
From The Cube Orange/+ With ADSB-In Overview — Copter documentation, SERIAL5 is connected to the internal ADSB receiver.
If it’s not an ADSB carrier, then serial 5 may be available. But if it’s the standard ADSB carrier, then I’m pretty sure serial 5 is stuck as ADSB only.
