I have a raspi with mavproxy and two different --out parameters.
First –out is for the GCS with write and read access
Second –out is just for monitoring which should only be allowed to read the udp stream
I read that with * set mavfwd false the --out can be limited to only read but can I set this also just for one specific --out command?
Any help is very much appreciated
