Is it possible to split the logs for different models to separate folders?
Thanks
Chris
Thanks
Chris
I’m pretty sure it already does this based on frame type and also if you are using different FCs for each.
change the sysid for each model, and this will happen all by itself
Sysid did the trick, many thanks. That makes sorting the logs easier for multiple Arduplane equipped models.
Chris
