I’ve got a problem with understanding how Cam1 parameters work alongside Cam2. I have three cameras. Two of these cameras share a PWM trigger input from my Aux1 port. The third camera has its’ own PWM trigger input from the Aux4 port.
I have configured both of these aux ports as “Camera Trigger” from the Servo Outputs page. However, both ports seem to be defaulting to Cam1 settings.
Cameras 1+2 need a PWM signal that holds the signal high for 0.5s. Anything shorter than that, and it isn’t detected. Camera 3 (Cam2 in parameters) needs a signal that lasts for only 0.1s. Anything longer than that, and multiple captures are taken. It is imperative that the number of captures is equal across cameras.
How do I configure Aux4 to use Cam2 parameters? I realize they are both “servo” cameras, but I thought I could give separate PWM settings to Cam1 and Cam2?
Again, right now, Cam2 settings seem to be ignored, and Cam1 settings are used for both Aux outputs.
