Sending Single MAVlink command - MAV_CMD_START_RX_PAIR
Is it possible to send a single Mavlink command? Like typing it into a serial line?
I need to send MAV_CMD_START_RX_PAIR(1,0) to my Cube in order to pair/bind a Yuneec SR24 RX with an ST16 TX. As detailed here under “RC Binding”:
https://developer.yuneec.com/documentation/133/Custom-Payload
RC Binding
To bind RC, you either need to send the bind command with param1 = 1, param2 = 0. Or alternatively, you can flip the H520 upside down. If it is in bind mode, the LEDs will flash yellow.
The SR24 is connected via the SPKT/DSM port; but looking at the MAVlink documentation: http://mavlink.org/messages/common [which appears to be down, co here is an archive: https://web.archive.org/web/20180831170844/http://mavlink.org/messages/common]
MAV_CMD_START_RX_PAIR Starts receiver pairing
Mission Param 1 0:Spektrum
Mission Param #2 RC type (see RC_TYPE enum)
…it is written as if the default (and only) value for Param 1 is 0 ==Spektrum.
So I assume mission planner uses Param 1 == 0 for the Spektrum binding process.
Hence why I need to send a single MAVlink command with param 1 == 1 and Param #2 ==0 as shown in the Yuneec documentation:
