Hi
I have try severals selflock props, but I alwas get a lot of vibrations after use them. Any one has use some that can recommend to use?
Im using 15" to 20" props
Thanks!
Hi
Thanks!
I have a set that work great. Will see if I can find out where I got them. I thought it was at RCtimer…will check.
thanks!! I will get a couple!
what props are you using with those?
16 inch and another bird with 18 inch.
They worked great for me…but I won’t lie I bought them a few years ago…things could have changed.
thanks! I will try and let you know if are the same!
good Luck Alberto. I hope they work out for you. For me I loved them so much I use them on two drones.
