Hi, i have some troubles with my paylaod interfering with my gps ( actually here 2 on L1 band 1 575,42 MHz). i’m using arduplane v4.0.5.
i would try to install a multiband L1/L2 and just use the L2 band ( 1227,60 MHz) to make some tests.
i probably us this gps reference
ublox chip.
is it possible to select the band in mission planner?
is anyone had issue to select only L2 band in ublox center for a gps?
what will be the mission planner reaction if i use a L2 only antenna with this gps to catch only L2 data?
