Hi everybody
I am recording both filtered and raw data logs on my micro SD card through (HCSD, 4GB) Pixhawk but the SD card speed is not fast enough to record both filtered and raw data at the right rate for the Pixhawk`s sensors. Has anyone have ever searched regarding the fastest SD card that can be used in Pixhawk?
I searched but did not find anything related.
Thanks
I am sure SD Card speed has been discussed on these forums. If you “searched but did not find anything” then I recommend that you try again.
Could you perhaps clarify your exact question?
I’ve used class 10 and U1 cards
I just replaced the SDcard in my PIxRacer for the same reason and this one works well under all logging conditions. Proven viewing FFT in Mission Planner. Great value at ~$10
