sunama
(abu)
September 26, 2017, 9:01pm
#1
Hi
I have received the pixhawk 2.1, but no micro sd card (msdc).
I have a spare 8GB msdc, so this is not a problem.
So, do I simply put a blank/formatted msdc into the slot?
Also what format should I use? NTFS, FAT32?
Or do I copy an image onto the msdc?
Thanks
hunt0r
(Hunt0r)
September 27, 2017, 5:44pm
#2
You want a blank micro SD Card. If it’s not already, format it as FAT.
sunama
(abu)
September 27, 2017, 9:43pm
#3
Hi @hunt0r
Thanks for the info.
Droider
( D)
September 29, 2017, 3:47pm
#4
Just looking for the slot now? Where is it?
hunt0r
(Hunt0r)
September 29, 2017, 5:56pm
#5
@Droider I don’t understand your question. Are you asking “Where is the SD Card slot on a PixHawk 2?”
skyveyor
(David)
September 30, 2017, 12:21am
#6
FAT is only good up to 2GB cards.
Droider
( D)
September 30, 2017, 2:24pm
#7
@hunt0r I was having a ‘Blond’ moment! thanks for the query!
sunama
(abu)
September 30, 2017, 3:12pm
#8
I will be using a 8GB card, so I guess only 2GB of it will be available to be used.
hunt0r
(Hunt0r)
September 30, 2017, 3:42pm
#9
Hrmm, I think my cards are more than 2GB. Maybe VFAT or FAT32 would work too? I guess the easiest thing is to try it and see.
JoeBreznai
(Joe Breznai)
September 30, 2017, 4:07pm
#10
I use FAT32 all the time- works fine
Joe
skyveyor
(David)
September 30, 2017, 6:53pm
#11
I think FAT32 works in the pixhawk. I’ve been plauged with a bad logging problem for months. Someone suggested FAT formatting might help.
