I’ve enabled the scr_enable parameter still not able to get the scripts folder while actually connecting to the controller, but when I use SITL I’m able to get the scripts directory.
I’m not able to figure out the problem
I’m not even able to create a folder .
It shows "failed to create directory ".
Remove the SD card.
Plug the SD card into your computer.
Inside the APM folder, create a folder called “scripts”.
Plug the SD card into autopilot.
Does this help?
Also, which version of Mission Planner you are using?
It should work.
