@BenBBB he will have it running a small airport using wet string and a coat-hanger.
I eventually got around to testing the modified version of @ppoirier s POC Arduino code, all of the VL53L0x sensors are detected by ardupilot as independent sensors at addresses 41 42 43.
#include <Wire.h>
#include <VL53L0X.h>
//#define XSHUT_pin6 A7 //not required for address change
//#define XSHUT_pin5 A6
#define XSHUT_pin4 A3
#define XSHUT_pin3 A2
#define XSHUT_pin2 A1
#define XSHUT_pin1 A0
//ADDRESS_DEFAULT 0b0101001 or 41
//#define Sensor1_newAddress 41 not required address change
#define Sensor2_newAddress 42
#define Sensor3_newAddress 43
#define Sensor4_newAddress 44
#define Sensor5_newAddress 45
#define Sensor6_newAddress 46
VL53L0X Sensor1;
VL53L0X Sensor2;
VL53L0X Sensor3;
VL53L0X Sensor4;
//VL53L0X Sensor5;
//VL53L0X Sensor6;
void setup()
{ /*WARNING*/
//Shutdown pins of VL53L0X ACTIVE-LOW-ONLY NO TOLERANT TO 5V will fry them
pinMode(XSHUT_pin1, OUTPUT);
pinMode(XSHUT_pin2, OUTPUT);
pinMode(XSHUT_pin3, OUTPUT);
pinMode(XSHUT_pin4, OUTPUT);
// pinMode(XSHUT_pin5, OUTPUT);
// pinMode(XSHUT_pin6, OUTPUT);
Serial.begin(115200);
Wire.begin();
//Change address of sensor and power up next one
// Sensor6.setAddress(Sensor6_newAddress);//For power-up procedure t-boot max 1.2ms "Datasheet: 2.9 Power sequence"
// pinMode(XSHUT_pin5, INPUT);
// delay(10);
// Sensor5.setAddress(Sensor5_newAddress);
pinMode(XSHUT_pin4, INPUT);
delay(10);
Sensor4.setAddress(Sensor4_newAddress);
pinMode(XSHUT_pin3, INPUT);
delay(10);
Sensor3.setAddress(Sensor3_newAddress);
pinMode(XSHUT_pin2, INPUT);
delay(10);
Sensor2.setAddress(Sensor2_newAddress);
pinMode(XSHUT_pin1, INPUT);
delay(10);
void loop()
this should also work for the VL53L1X, the code compiles with the libraries swapped out.
