Hey guys! I have a question for which I am hoping someone can offer some insight. I have a pixhawk driven Hex that is carrying a nex5 on a three axis gimbal with slipring for 360 degree rotation. Due to limited wiring through the slipring, I only have one set of signal wires to run SBUS to my Alexmos gimbal controller.
What I would really like to have is at least 4 channels running through the pixhawk sbus out in order to control the gimbal. I currently have my ch 8 in/out set to control the gimbal pitch. I set my CH7 in/out as an RC Passthrough to control my shutter on the camera.
I would also like to have a control channel for Yaw, as well as a channel to control gimbal controller modes. My problem is that SBUS out only seems to send out channels 1-8. As it is a hex, my first 6 channels are tied up with ESC motor outputs which only leaves me with channels 7 and 8 to work with. To complicate matters further, I would still like to be able to trigger autotune but I don’t have a channel to trigger it without reconfiguring channel 7 and 8.
I did use a PPM encoder to re-encode the servo outputs from the pixhawk, but it added yet another piece of hardware and also introduced twitches to the pitch control so that didn’t seem to be the best solution.
Does anyone know if there is any way to send channels 8-14 through the SBUS out on a pixhawk or is there a way to switch motors to run on a different set of channels rather than ch1-6? What would be awesome is to just have all 14 of the channels output through the SBUS out port.
The only help I can offer is that Copter-3.3 supports the 32bit AlexMos controller through a telemetry/serial port although it’s not well tested and we have no documentation on how to set it up. Here are some parameter settings that I think are required:
MNT_TYPE = 3 (to set mount type to AlexMos serial)
SERIAL2_PROTOCOL = 7 (to specify telem2’s protocol is AlexMos serial)
BRD_SER2_RTSCTS = 0 (to turn off flow control for telem2)
After changing these parmeters the Pixhawk (or similar) should be rebooted.
y-harnessing the sbus to the pixhawk and the alexmos 100% works. I set it up today.
i have tilt on channel 6 and pan on channel 12.
i gave the alexmos serial connection a try yesterday. It worked!!! first try, i was surprised. the only issue had had that was when you change MNT_JSTICK_SPD to a speed, the camera movement is choppy, i’m guessing it’s serial communication issue. I didn’t test it out further, i just switched to controlling through sbus. But i’ll give it ago after i get this project done.
@PIEngineering,
I think you’re one of the first people to give the AlexMos serial connection a try. I was wondering, could you give me instructions on how to connect the AlexMos gimbal controller to a Pixhawk? I’d like to create a wiki page on how to do it.
It’s the physical serial lines that I don’t know how to connect so maybe a picture or something would be good. You could mail it to drones-discuss@googlegroups.com.
I know all the parameter settings that are required so that part is ok.
I am wondering if should order alexmos
I really want to go with it because encoders look simpler to integrate.
But don’t want to chase my tail getting it hooked up.
So did you get yours working?
I am controlling a SBUS gimbal with the pixhawk SBUS output, using channels 10,11 and 12. All you have to do is set BRD_SBUS_OUT to 1 and Servo10, 11 and 12 to 1 (RCPassThru). Just saying it because no one seems to have posted this simple method.
Hi Sergio, if I got it right you connected the gimbal to “SBUS out” (on Pixhawk 4 I suppose) and Passed Thru 3 channels in order to manage tilt, pan and mode directly from your transmitter. Those channels are coming from a receiver connected in SBUS as well. Correct?
Yes it will work, but even better is when you correctly configure the gimbal:
SERVO_10_FUNCTION = Gimbal-roll
SERVO_11_FUNCTION = Gimbal-pitch
SERVO_10_FUNCTION = Gimbal-yaw
And then configure the MNT_RC_IN_x parameters
Then it will work as a RC pass-thru AND obey mavlink commands as well.
That is correct, I haven’t tested it with pixhawk 4 but it worked with a cube orange and an mRo x2.1. I don’t remember which SBUS receiver I was using, some FrSky for sure but I don’t think that matters.
Edit: what Amilcar Lucas says makes more sense, I didn’t do it like that because I didn’t know there were gimbal functions in the servox_function parameter, sadly I don’t have a sbus gimbal right now but you should give it a try.
