SBUS Non-Inverted
Does anyone know if there is a way to tell pixracer to accept non inverted SBUS.
I have a recessive that appears to be outputting non inverted SBUS. I can hack the receiver to work, but thats messy and so the question.
Cheers
Check on chibios gitter I think there is some parameters you can set for the PixRacer
hahahaha
I have no idea what you just said.
But I think I found it. It’s some form of live chat.
Yep , this is where developpers meet, and your question is “a propos” for the room. Looking at the code here. https://github.com/ArduPilot/ardupilot/blob/master/libraries/AP_HAL_ChibiOS/hwdef/fmuv4/hwdef.dat
I followed your link but it means nothing to me.
Not a programmer. lol
Ok I see you asked,perfect
Merci beaucoup mon ami
So you have a test load baked by the Wizard himself ?
Ya.
Sadly it made no difference, which is really odd.
Rick: did you find software solution for this?
no I didn’t.
I have another receiver coming and will try again. If its still a problem I have an SBUS inverter I can try. In talking to Tridge one of the developers the code should handle the inverted signal but I couldn’t get it to work. But I am NOT suggesting this is a Skydroid issue.
I use ppm now, but loose channels, after some flys Im going to give a try too and comment.
