Savety switch LED: Quick, constant blinking / Flies fine / Pixracer
Hi all,
Yesterday I installed AC3.6dev on a new pixracer copter (APM:Copter V3.6-dev (f0f7ca23)). I was in the air for about 1.5 hours and all was fine. However, the savety switch LED was not solid. it was more a
Quick, constant blinking: Performing system check. Please wait.
as described in the wiki at: Safety Switch — Copter documentation
EKF2 was healthy, all flags ok. It was the same behaviour in all flights.
So my question is if this is a new behaviour, a bug or some issue with the copter?
If it is related to the copter setup, what should I look for?
Thanks a lot in advance,
Thorsten
It’s a (very recent) bug, should be fixed today when I merge a PR.
Hi Francisco,
thanks a lot for the feedback! Very much appreciated!
PR has been merged. In about 4 hours it should be built in master version. Please let me know if it works or not.
I just saw that you merged it. Will try tomorrow morning.
There are some other strange things happening. But I’ll open a separate discussion in a couple of minutes…
Works! Thanks again!
