Hello guys,
Please excuse me if I do something wrong by posting this, but I am not used to forums since a long time, so I would probably miss some stuff…
Anyway, The problem is that I don’t know if I’m doing everything wrong or if I found some bug in the “Save Trim” function.
Here is the thing I’ve done to use the “Save Trim” function :
[ul][li]I set the correct button (Thr Cut in my case) to the channel 7 “Save Trim” function in the APM Planner.[/li]
[li]Then put every trim to it’s default position and ensure channel 7 is off.[/li]
[li]Arm the beast.[/li]
[li]Take off (in “stabilise” mode) and hover while setting the trims.[/li]
[li]Once the trims were correctly set, I just landed and disarmed it.[/li]
[li]Then turned the “Save Trim” switch on for something like 3 seconds, then off.[/li][/ul]
That’s all for the procedure. (I hope it’s the correct way to do it)
Here comes the issue :
After that procedure done, I took all trims back to their default position, rearmed the quad, tried to take off, and guess what happened…
The quad left the ground by drifting the same way but even stronger.
After some tests, I’m asking myself : Could it be the orientation of the apm ?
Because I oriented mine upside down in a 180° roll, and noticed that the problem does seem to occur only for the roll axis.
So, I think that it could be possible that the"Save Trim" function doesn’t care of the orientation parameter of the APM, and that’s why it seem to strengthen the roll instead of getting rid of it.
And if I’m right, maybe this bug is also causing trouble in other function (like “AutoTrim” or “Autotune”).
I didn’t mention that if I just keep the trims on the controller without saving them to the apm, everything works fine, so I don’t think I missed something in the configuration.
Except this little issue making me crazy, I just want to thank you all for that work, the thing you made is just incredible and also open-source. I love that, and perhaps, if I have enough interesting ideas to improve this project, I will begin to help you make it go further, I’m not bad at coding and electronics (at least better than in English) so please guys, wait for me .
