Hi everyone, I would like to showcase some of the work I have recently done on a sailboat. The sailboat runs Ardupilot(Obviously), but all the control systems are done using lua scripts. I also developed a simulation of this specific sailboat that can be used to prototype and develop control systems that can then be implemented in Ardupilot. I have written quite a lot of Lua scripts ranging from stability tests, to rudder step responses, PI-Controller, sail winch state machine, UART wind sensor (can send other sensor data as well) and a navigation state machine. Here is a link to a video of the sailboat performing a step https://www.youtube.com/watch?v=FQ0VcICqiJs.
I will continue to post results from my test on this topic. I would also like to commit my Lua scripts to ardupilot git, as it makes use of a mathematical approach to design the steering control by performing tests and looking at the yaw angle, yaw rate and rudder angle. I believe the results from the scripts can also be used to build on the existing code for sailboat. This project is my Masters in Electronic Engineering so I will at the end of this year have a detailed document on the control systems and the results.
Thanks very much for sharing! We’ve got some instructions on the wiki here for raising PRs to contribute back to AP.
FYI @iampete is our sailboat maintainer.
