Saftey switch disable
i read about the posibility about disabling the safety switch. (BRD_SAFETYENABLE 0)
When i have disabled it, the Motors are arming, but not Spinning when i throttle up. (copter armed)
Running copter 3.4.3
Does someone have the same Problem and knows the solution?
Thanks!
Hey, Has it passed all the prearm checks?
Share a video or .tlog
Good day, if you want arm your motors you need also disable the arm checks.
Pls update your firmware to the 4.0.5
