I have created a 120 kg rover and would like to install a safety flashlight, which lights up when the rover moves forward, whether in manual or automatic mode.
I only need the light to work when the rover is moving, because in automatic mode I expect it to take long breaks during these GPS runs.
It is a Skid steering rover equipped with an Orange Cube and a MAUCH power module.
I have thought about several systems such as:
install a sensor on a wheel shaft
measure the current at the level of the motor to trigger the system, etc …
But in the end, it doesn’t quite suit me.
I wanted to know if I could drive a relay through the Cube. For example, as soon as the throttle’s PWM is not at neutral, I activate the relay.
Or, connect a microcontroller between the Cube and the Cube’s current sensor to drive a relay. For example, if the current is greater than 2A, I operate the lamp.
To save you a little time/trouble, speed (m/s) can be stored in a variable like this:
local speed = ahrs:groundspeed_vector():length()
Once the AHRS is active/healthy, the vector will almost always be non-zero, so you’ll want to establish a non-zero threshold above which the light relay is activated.
The problem in this case is that you need GPS information.
Now, I want the flashlight to work as soon as the rover moves forward, for example, if I take it out of a truck in manual mode, there will be no GPS signal.
I was thinking either:
be able to read the accelerator’s PWM while operating as follows:
if (throtlle_pwm <1490) or (throtlle_pwm> 1510), then activate a relay
another less elegant solution by reading the current consumed:
if (current_read <2 amps), then activate a relay
local RELAY = 2 -- relay to control
local THRESHOLD = 0.01
local FREQUENCY = 200 -- (ms)
local THROTTLE_INDEX = 3
local STEERING_INDEX = 4
function throttle_disengaged()
local throttle = vehicle:get_control_output(THROTTLE_INDEX)
local steering = vehicle:get_control_output(STEERING_INDEX)
if math.abs(throttle) + math.abs(steering) >= THRESHOLD then
relay:on(RELAY)
gcs:send_text(5, 'Lights: ON')
return throttle_engaged, FREQUENCY
end
return throttle_disengaged, FREQUENCY
end
function throttle_engaged()
if math.abs(throttle) + math.abs(steering) < THRESHOLD then
relay:off(RELAY)
gcs:send_text(5, 'Lights: OFF')
end
end
gcs:send_text(6, 'Lights: Script active')
return throttle_disengaged()
I’ve been meaning to look at the vehicle:<control output> methods anyway, so this gave me good reason to see how they work. In this case, the throttle variable is commanded throttle output percentage (0.0 to 1.0).
I think the relays are 0 indexed in Lua, meaning that if you configure relay 3 in the parameters, you’ll reference relay 2 in Lua.
I almost replied yesterday to mention that it may not work in reverse, but then thought I should do some testing of my own before that. Thank you for testing it before I had the chance!
EDIT:
I edited the code in the post above, and it should now work in reverse and during pivot turns with the addition of math.abs(throttle) + math.abs(steering).
