Mate, power consumption is NOT calculated by the battery capacity.
Each device on your drone is rated for a specific power consumption.
For example, look at the motor specification below.
In the last table, you can see a column named Power (W).
When you fly your quad, each motor takes up a certain amount of current, depending on the load (prop size, weight of the quad, internal resistance, etc.).
Whether you use a 4S battery (4.2*4 = 16.8V) or a 6S battery (4.2*6 = 25.2), the motor will consume the same amount of power, but the current draw will be lower (P = V x I).
Also, the battery capacity is calculated this way.
Volts per cell * Number of cells * Capacity
6S 1300mAh will have a capacity of 4.2 * 6 * 1.3 = 32.76 Wh when fully charged.
By using 2 x 850 mAh 4S cells, the total capacity will be 4.2 * 8 * 0.85 = 28.56 Wh when fully charged.
When the battery capacity is lower, it simply means your quad will fly for a shorter time. Not that the power draw is lower. (In that way, if you remove the battery, the power draw is 0; your quad should fly forever.)
This is referring to the C rating of the battery. The battery links you have provided have a C rating of 130.
Which means they are capable of providing 130 * Capacity Amps of current draw.
1300 mAh at 130 C = 130*1.3 = 169 A continuous power draw.
From the reference motor above, it consumes 35 A at 100% throttle on 6S (24 V). 4 such motors at 100% throttle can consume a total of 140 A, but it is highly unlikely that you will fly at 100% throttle anytime unless you are racing.
You are spending way too much time worrying about things that you do not understand. I suggest that you spend more time reading about the components.
You can read this blog: How To Get Started With FPV Drone - The Ultimate Beginner's Guide - Oscar Liang
Or watch Joshua Bardwell on youtube.
