I was trying to make sure that all components are compatible and so I reached out to Hobbywing to ask if ‘6S capable’ also included 6S LiHV batteries? They responded with “sure, use them… but nothing under 75C because they are usually low quality”. Any battery over 5A 6S runs at 60C, 45C, or even 25C - which should work fine for energy consumption. What do you guys think?
The LiHV batteries are only about 0.1V higher nominal voltage than the typical ones, so I would not foresee any compatibility issues, except maybe for your charger.
