Is there a way to do this? I don’t mind using powershell if it can be done in powershell, vs regular command line. I’m using windows 7. Any help is appreciated, thanks.
Absolutely. So, my end goal is to run mission planner from the command line via a script that is run remotely. I’d like to have a few different config files to load, so I have a few of those that I would like to open when mission planner starts.
So, there’s a couple of things I think I could do. I can either have a batch script, or something in powershell that runs mission planner with a specific config file as an argument (not sure if that’s possible…but doesn’t look like it), or, another option would be something like set mission planner to load a specific config by default, and just change whichever config file I want to load to the name of that file.
I’m still not sure if either of those are possible.
