Copter completed 1 waypoint and after that I change it into loiter mode then I flew copter just outside fence. It shows warning " Fence Breached " , and changes its mode to RTL or smartRTL but it could not able to move from that position, even after change mode to RTL or smartRTL manually.
I added breach point also, still not working.
And if we set OA_TYPE to 3 and do same above procedure, then it is showing warning/error message " Dijkstra could not find path " and stuck on current position.
You might be able to use Stabilise mode or even AltHold to return to the inside of the Fence.
I dont understand how you ended up outside the Fence though…
When I tested recently I found:
In Loiter mode I could NOT make it do an RTL or breach just by pushing against the fence radius or altitude. I just could not exceed the fence boundary.
In AltHold mode I could breach the fence radius which caused RTL, but could NOT breach Altitude.
In Stabilise mode I could breach altitude and radius, which initiated RTL in each case.
This section of your log seems to indicate that you properly uploaded an inclusion fence. I think “98” is the flag for that. When I run a similar mission with an exclusion fence, that field changes to “97.”
